Date/Time: Sun, 02 Aug 2026 05:41:16 +0000
Futures Forward Curve
View Count: 1983
[2014-12-19 15:18:45]
Adam - Posts: 141
Hi im a new user (very impressed with SC though).
do you have the ability to see a full futures forward curve? so can see the current prices on all entire issue for crude out to say 2018 and see the contango curve (also the ability to see change on previous day or month etc).
here on the CQG link its slide 11 http://www.cqg.com/docs/cqg_yield_forward_curves.ppt
Thanks in advance
Adam
Date Time Of Last Edit: 2014-12-19 15:19:04
[2014-12-19 19:03:34]
The only thing we can suggest is to set up a Quote Board that lists all of the contract months you want to look at for a particular futures market:
Getting Quotes
Date Time Of Last Edit: 2014-12-19 19:03:51
[2014-12-19 19:08:31]
Adam - Posts: 141
Hi
This doesn't show the curve changing though graphically, maybe i could create an overlay of say 10 charts in a histogram format?
[2014-12-22 19:12:03]
Sierra Chart does have an Overlay study. It is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s100
However, not quite sure what you mean by the Histogram format for chart bars.
