Date/Time: Fri, 22 Nov 2024 13:48:39 +0000
ACSIL - How to capture "reload" event
View Count: 1703
[2013-05-20 20:06:09] |
ejtrader - Posts: 688 |
SC Team - I am running into a small issue where the variables doesn't seem to be not cleared up properly and can attribute to "reload" event ( insert key ). What's the event id that I can use to capture the reload events(insert key or any other events - where SC would perform full recalculation)? Thanks Date Time Of Last Edit: 2013-05-20 20:06:58
[2013-05-22 05:08:12] |
You just need to check sc.Index == 0. This is very accurate.
