Date/Time: Sat, 21 Dec 2024 16:47:36 +0000
Error creating Alert manager
View Count: 874
[2014-12-19 13:48:49] |
bwasi - Posts: 34 |
Dloaded latest version 1217 then got this window alert
ScreenHunter_60 Friday, December 19, 2014 21.43.gif / V - Attached On 2014-12-19 13:48:09 UTC - Size: 7.03 KB - 325 views |
[2014-12-19 17:59:47] |
We recommend restarting your computer and see if the error goes away when starting Sierra Chart. If not, then delete the SCAlerts.JSON file in the Sierra Chart folder before starting Sierra chart. There may be a corruption with that file. There are backups of this file in the Backups subfolder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
