Date/Time: Wed, 14 Oct 2026 04:17:14 +0000
fxcm fix not accepting oco stops with ordee
View Count: 1497
| [2014-12-19 13:27:32] |
| User730885 - Posts: 8 |
Hi my limit and stop oco orders are being rejected FXCM FIX: Received a Reject <3> message. Reference Sequence Num = 37. RefTagID = 67. Reference Message Type = E. SessionRejectReason = 15. Text = Out of order repeating group members | 2014-12-19 08:23:01 * FXCM FIX: Received a Reject <3> message. Reference Sequence Num = 38. RefTagID = 67. Reference Message Type = E. SessionRejectReason = 15. Text = Out of order repeating group members | 2014-12-19 08:23:01 * |
| [2014-12-19 13:32:21] |
I am using ver 1217
| [2014-12-19 18:07:26] |
This problem has been solved in the latest prerelease, but there were other changes in that version required by FXCM which are not yet supported by FXCM on their live servers, so we cannot have you update right now. But we will work on some changes before the end of the day to work around this limitation on the FXCM live server. We should have this all done by the end of the day. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-12-20 20:13:04] |
We did not get the release out yesterday, but we are working on it now and it should be out this evening. Look for version 1220.
| [2014-12-21 21:15:43] |
Version 1220 is now released. Update by selecting Help >> Download Prerelease.
| [2014-12-23 14:50:40] |
Thanks but i still have a problem FXCM FIX Trading session: Received a Reject <3> message. Reference Sequence Num = 52. RefTagID = 68. Reference Message Type = E. SessionRejectReason = 1. Text = Required tag missing | 2014-12-23 09:04:43 * |
| [2014-12-23 18:03:54] |
We apologize for this. We are going to test this now and correct the problem. Will let you know when the new release is ready. Should be in about 30 minutes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-12-23 19:08:04] |
We have released a new Sierra Chart revision of version 1220. Update by following these instructions here: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
