Date/Time: Sat, 21 Dec 2024 17:14:59 +0000
Option Symbol:
View Count: 865
[2014-12-18 22:57:51]
User22591 - Posts: 133
I have tried to follow your instructions without success.
My Support Entry from Chart Window is checked through Global Setting.
I have placed my option Symbol on the Title Bar.
From the chart setting window I add the Symbol to the symbol box.
When I hit OK I get a blank screen. All Chart information is lost.
What did I missed or did wrong?
Winston
770-645-9998
[2014-12-19 04:07:36]
What is the option symbol you entered within Chart >> Chart Settings?
Keep in mind the use of options with Interactive Brokers is complex and problematic. The option symbol has to be properly specified otherwise you will market data.
Date Time Of Last Edit: 2014-12-19 04:08:06
