Date/Time: Sat, 21 Dec 2024 17:12:11 +0000
MACD overlap
View Count: 958
[2014-12-18 19:29:51] |
User21575 - Posts: 3 |
hi, for ES, NQ and YM chart, when i add a mutiple MACD indicator, it happen to overlapping, no matter how many i add. btw, ther are no problem for RSI,AO and volume indicator. thanks. http://www.sierrachart.com/image.php?l=1418930877790.png |
[2014-12-18 23:21:01] |
In the Study Settings window there is a Chart Region setting. Make sure each study is set to a different Chart Region.
