Date/Time: Mon, 23 Dec 2024 07:06:55 +0000
colour surrounding candlestick
View Count: 964
[2014-12-18 17:29:02] |
User28696 - Posts: 7 |
Hi, my background is black and i use candlesticks which are either green or red but is there a way to remove the white surrounding those candles? I changed everything in chart settings to remove anything white but it is still there. Thanks |
[2014-12-18 17:39:55] |
Sierra Chart - Max - Posts: 5756 |
The outline colors are set through the Graphics Settings: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html For candlesticks, you will want to update the: CandleStick Up Outline CandleStick Down Outline Sierra Chart Support |
[2014-12-18 17:45:37] |
Thanks, i just saw the little checkbox: use global settings instead. so i changed it in the global settings and it works.
