Date/Time: Mon, 23 Dec 2024 06:50:34 +0000
Numbers Bars
View Count: 902
[2014-12-18 16:18:35]
User68117 - Posts: 65
Hello, please respect the setting Numbers Bars somehow set it up to me to screen numbers (red / green) color dyed only if the two conditions are met? Comparison using "Text On Diagonal Dominant Side". I would like to put on a diagonal compared with dyed my only value in the event that:
- A numerical difference will be greater than 150%
- Number will be greater than 100
How to set up?
thank you
imageNB.png / V - Attached On 2014-12-18 16:18:11 UTC - Size: 127.97 KB - 393 views
