Date/Time: Sat, 21 Dec 2024 16:54:27 +0000
Is there a way to load a certain # of bars?
View Count: 884
[2014-12-18 16:09:24] |
infpz - Posts: 826 |
rather than days, as in the "days to load" section of Chart Settings?
[2014-12-19 10:20:13] |
No, definitely not and this will never come. It is impossible and extremely inefficient to implement and is loaded with problems. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-19 10:20:50
