Date/Time: Mon, 23 Dec 2024 07:06:37 +0000
switch off default order confirmation
View Count: 867
[2014-12-18 14:42:19]
User235423 - Posts: 8
I would like to know how to switch off the default order confirmation as every time my connection breaks it auto adjust back to order confirmation needed.
best regards
Mats
[2014-12-18 16:14:52]
Sierra Chart - Max - Posts: 5756
Regarding Order Confirmations, refer to the documentation here:
https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#OrderConfirmations
Sierra Chart Support
[2014-12-18 17:50:29]
This is impossible:
The only reasonable explanation for this, is you have opened a new chart or Trade DOM and the confirmation settings are at default.
Or you have a Trade Window configuration that you are selecting which has the confirmation options enabled.
