Date/Time: Sat, 21 Dec 2024 16:57:05 +0000
Coloring Number Bars?
View Count: 961
[2014-12-18 09:13:44]
Halco - Posts: 92
I have Number Bars with "Number Bars Text" set to "Dominant Side Volume Percent". Using the input settings is it possible to color those bars (preferably the text) something like this: 50-60% Color 1, 61-70% Color 2, 71-80% Color 3, 81-100% Color 4. For example, I would use shades of green for the Range Up Colors, shades of red for the Range Down Colors.
If this is possible, which setting would I use for the "Text Coloring Method" input and the "Column Compare Thresholds" input (or any inputs that would accomplish this)?
Thanks!
[2014-12-18 09:27:05]
Not sure this is possible. We need to check on this.
[2014-12-19 16:25:36]
Al SC Developer - Posts: 434
In ver 1220, a new text coloring option has been added: "Based on Dominant Side Volume Percentage". Use this new option and set the compare thresholds to 60, 70, 80.
Date Time Of Last Edit: 2014-12-19 19:28:58
[2014-12-19 16:52:40]
Halco - Posts: 92
I now have ver 1218 but I cannot find the choice "Based on Dominant Side Volume Percentage" in the text coloring options.
[2014-12-19 19:21:04]
Halco - Posts: 92
I have ver 1219. I still don't see that option in the text coloring options.
[2014-12-19 19:29:22]
Sorry for the confusion, it will be in ver 1220.
