Date/Time: Sun, 08 Sep 2024 00:43:04 +0000
FXCM + Sierra Chart + Range bar possible?
View Count: 849
[2014-12-18 06:15:30] |
User38993 - Posts: 61 |
Hello if I open an account with FXCM, can I use Sierrachart and rangebar? Let's say 5 pips in one bar? |
[2014-12-18 06:32:29] |
Yes. You also need a direct account: http://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-18 07:00:20] |
1. I already have a sierrachart with ampfutures, but I need a separate account? 2. Does package 2 not have range bar and moving average option compare to package 3? 3. If I need to purchase a direct account, can I just get package 2 instead of more expensive version? 4. Also I have an interactive brokers account as well. Do I need to buy a separate account for this? |
[2014-12-18 07:46:43] |
1. Yes. Definitely. 2, 3. You cannot use Service Package 2 with FXCM. 4. You need your own direct Sierra Chart account and can use it with any Data/Trading service you want. And you can have multiple installations of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
