Date/Time: Mon, 23 Dec 2024 07:03:19 +0000
SC sends unintended order when hitting spacebar in hibernate mode
View Count: 1005
[2014-12-18 05:50:56] |
TraderTen - Posts: 80 |
This has happened to me again today. I had no trade DOM up, but had a trade window open. So PC goes into hibernate mode and upon hitting space bar to revive it, SC submits an automatic order which is executed and immediately stopped out for a $50 loss. This is the second time. Is it necessary to close the trade window to prevent this?
[2014-12-18 06:29:38] |
The only reason this would happen is if one of the trade window buy/sell buttons has the focus and the pressing of the space bar would press it. This could be the case if the Trade Window is not attached to a chart or Trade DOM and you previously pressed one of the buy/sell buttons and the Trade Window itself is active. In the next release, we will always take the focus away from those button and give it to the Trade Window itself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-18 06:30:03
[2014-12-18 16:31:53] |
Well I appreciate this info; however, for your info when making the change, be aware that I have never initiated an order using the Buy or Sell button, however I have often used the Flatten button, so you might include that one in your update as well.
