Date/Time: Mon, 23 Dec 2024 06:17:10 +0000
Bar periods problem for fx futures
View Count: 832
[2014-12-18 01:27:15] |
AC95366 - Posts: 24 |
Hi Support! Software version: 1217 data feed: AMP CQG Only tick charts available even change to 1 minute or 1 Hour bar periods the problem only on symbol: J6(JPY), B6(GBP), S6(SF), and US dollars index. (other FX futures are fine) pls refer to attached , thanks. Date Time Of Last Edit: 2014-12-18 02:18:17
Private File |
[2014-12-18 02:17:05] |
Now just fond the Brent Oil have the same problem. |
[2014-12-18 03:07:00] |
There is some problem with the data from CQG. Re-download the data following the instructions in help topic 2.1.2: https://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
