Date/Time: Mon, 23 Dec 2024 07:00:55 +0000
Editing Pivot Labels
View Count: 866
[2014-12-17 22:33:24] |
User29511 - Posts: 19 |
Am I able to edit any of the pivot point labels? Eg. For Weekly I want to add 'W' to the PP, S1, R1 etc. And same for monthly only I would like to add 'M' Thankyou for any assistance if possible. |
[2014-12-18 04:02:02] |
Refer to the documentation for this here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#TechnicalStudySettingsWindow Your Sierra Chart account is showing expired. Log into the support board using the account that you use with Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-18 04:02:40
