Date/Time: Sun, 13 Sep 2026 22:37:41 +0000
Option Symbol
View Count: 1155
| [2014-12-17 21:42:57] |
| User22591 - Posts: 133 |
I have been trying to do paper trade for options using your trade window or DOM and cannot seems to figure out where on the window to place the symbol. There is a slot window within the chart window at the base just above Buy & Sell that seems to be the only area buy is NOT active. I am sorry but your literature does not provide simple explanation for someone to use your Trade window or dome to trade Options. Where should the symbol be placed when trading options? Winston Peak 770-645-9998 |
| [2014-12-18 04:20:15] |
An option symbol is entered through the Symbol box in the Chart >> Chart Settings window. Refer to the documentation for this here: http://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html#ChangingChartSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-18 04:20:32
