Date/Time: Fri, 29 Mar 2024 14:54:46 +0000
POC on a bar basis
View Count: 2254
[2013-05-20 17:07:49] |
User46635 - Posts: 3 |
I would like to prototype a POC statistical analysis tool. I need to be able to get the value of the POC Price level at any particular bar and periodicity. RJimenez |
[2013-05-20 17:13:28] |
STATISTICS How do you obtain values for.. -- Highest High for Session x -- Lowest Low for Session x -- TIC Increment -- Average Volume at Price -- Maximum trades at Price (MODE) -- POC Volume -- Open for US Session Highest High, Lowest Low |
[2013-05-21 01:06:21] |
You are able to highlight the Point of Control for any bar by using the Numbers Bars feature. Please see: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php Have a look at the available studies here: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html And also look at the Numbers Bars Calculated Values study: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#CalculatedValuesInputDescriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
