Date/Time: Wed, 16 Sep 2026 10:24:45 +0000
Wick color in an Above/Below study?
View Count: 1330
| [2014-12-17 13:25:24] |
| User623839 - Posts: 108 |
Is there a way to only color the body of the candle when painting in an above/below study? Basically to leave the wicks not colored? Much thanks guys! |
| [2014-12-18 03:20:28] |
Anyone?
| [2014-12-19 04:32:36] |
Try the Draw Style Color Bar Candle Fill
| [2014-12-20 03:17:09] |
I can make that work. Good job!
