Date/Time: Mon, 23 Dec 2024 06:10:00 +0000
study/price overlay
View Count: 1046
[2014-12-16 23:53:28] |
User35749 - Posts: 32 |
Dear Sir or Madam: For the Study/Price Overlay, how can I display the scale of the main price graph on the right and the scale of overlay study on the left? Thanks, Van |
[2014-12-17 04:47:35] |
Use the Left Side Scale: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html&CAID=#UseLeftSideScale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-17 17:12:57] |
dd78746 - Posts: 22 |
Hello, I am overlaying studies from a 15 min chart to a 233 Tick/Trade chart with IB data feed. Some of the overlayed studies do not update automatically. I have to manually recalculate the studies? Is there any solution to this? TIA dd Date Time Of Last Edit: 2014-12-17 17:17:23
[2014-12-17 17:20:09] |
It is hard for us to answer this question because we do not know the study configuration. In general this should not be a problem to begin with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-17 18:04:46] |
It does work very nicely on all charts. The problem seems to be with a 15 min Donchian Channel with a length of 15 & a displacement of 3 overlayed on a 233 trade/tick chart. If I remove the displacent (0), it seems to work fine.
Date Time Of Last Edit: 2014-12-17 18:05:35
[2014-12-18 07:44:29] |
Attach a Chartbook containing two charts with this configuration and no other studies other than these two studies described. Here are the instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
