Date/Time: Thu, 10 Sep 2026 03:20:47 +0000
ACSIL Question
View Count: 1319
| [2014-12-16 20:06:54] |
| Entropy - Posts: 36 |
I coding my own trading system in ACSIL and have a problem with sc.CrossOver(OscSubgraph, ShortEntryLevel) as ShortEntryLevel is a scalar and not an array. I thought perhaps the sc.CrossOver() was overloaded but it doesn't seem to be. How do I solve this problem? Also I want to make sure the close is above a moving average, sc.Close > MASubgraph, but I am not sure how to do this properly in ACSIL. Perhaps sc.Close[sc.Index] would work but how do I access last value of MASubgraph properly? Cheers, |
| [2014-12-16 22:15:12] |
| onnb - Posts: 666 |
1. Make a subgraph - populate its values with ShortEntryLevel - ShortEntryLevelSG[sc.Index] = ShortEntryLevel; 2. sc.Close[sc.Index] > MASubgraph[sc.Index] |
| [2014-12-16 23:03:17] |
Thanks! - that solve it. Cheers |
| [2014-12-19 04:36:38] |
You need to fill out an array with the integer value you want to use and pass this to the Crossover function. We recommend using one of the additional/extra Arrays on a Subgraph. Refer to this page for working with ACSIL arrays: http://www.sierrachart.com/index.php?page=doc/doc_ACS_ArraysAndLooping.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-19 04:36:59
| [2014-12-19 15:35:25] |
OK, good solution. Thanks!
