Date/Time: Wed, 12 Feb 2025 19:19:05 +0000
Show Order Fills on chart only shows orders made during the current day (no historical orders fr
View Count: 1501
[2014-12-16 19:54:53]
Colcan - Posts: 7
The Show Order Fills option only shows trades that I made during the current day. Historical orders from the previous day no longer show on my charts (they used to show up fine).
I have checked the Trade Activity Log and all the historical orders are present there. (they go back to Dec 2013).
These historical order fills however do not display on my charts though.. this issue started about a month/two ago.
Hopefully there is a quick solution to this? I've tried everything that I know of and have searched the website/support site thoroughly.
Thanks,
Mike
[2014-12-16 20:01:13]
Colcan - Posts: 7
Sorry, please disregard this support request. I just found the solution in the supporting documentation. Not sure how I missed this before.
Select Chart >> Chart Settings >> Advanced Settings. If you do not need to see any order fills in the chart for the prior trading day, then enable Load Order Fills for Current Day Only. If this resolves the problem with the Daily Profit/Loss calculation, then stop here.
Thanks,
Mike
[2014-12-17 10:24:55]
Yes, this is a new option.
It was on by default, but in newer versions is off by default.
[2020-11-12 07:48:09]
ycomp - Posts: 321
does the "Load Order Fills for Current Day Only" have performance issues if it is unchecked? I only ask because when you turn on showing order fills it takes some time to load, even if set for the current day only. I would like to disable this option on my all my charts but would like to verify that won't cause significant performance issues if i do that.
