Date/Time: Sun, 08 Sep 2024 00:41:20 +0000
Show Order Fills
View Count: 911
[2014-12-16 19:07:48] |
gmorgan111 - Posts: 121 |
For some reason the order fills are no longer being shown on my chart. I have show order fills show profit and loss enabled on my chart but it is not showing. Why is this not shown on my chart Thanks |
[2014-12-17 10:25:19] |
Go to the chart and uncheck the Chart >> Chart Settings >> Advanced Settings >> Load Order Fills for Current Day Only option. If this does not help, refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-17 10:29:34
