Date/Time: Tue, 23 Apr 2024 19:06:10 +0000
DTN IQFeed since update IQFeed manager log file sierrachart IQFe
View Count: 2424
[2013-05-20 15:50:28] |
YSS - Posts: 105 |
I updated to the latest stable of IQFeed manager. I use the tick data. I do not use any level II data. But after the update of the DTN manager i get this log message every second : IQFeed: Level 2 error: Account not authorized for Level II | 2013-05-20 11:48:49 Again, I do not use the Level II data from IQFEED, I use the level II data from IB. I use SC 964 because I read that newest versions do not work with Interactive Brokers ? Thanks for checking. Date Time Of Last Edit: 2013-05-20 15:51:32
[2013-05-20 16:14:31] |
We have implemented a patch for this. This message is continuously sent by IQ Feed. Please update by selecting Help >> Download Prerelease.
[2013-05-21 06:43:08] |
YSS - Posts: 105 |
Thanks for the quickfix. It's fixed. this is the log now: IQ Feed: Connecting. | 2013-05-21 02:41:12
Starting DTN IQ Feed interface software. | 2013-05-21 02:41:12 IQ Feed: Connecting to Admin port 9300 | 2013-05-21 02:41:12 The network socket is connected. | 2013-05-21 02:41:13 IQ Feed: Connected to Admin port. | 2013-05-21 02:41:13 AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2013-05-21 02:41:13 AdminMessage: S,STATS,,,,,1,0,0,0,,,Not Connected,5.0.0.11,,0,0,,0.03,0.0,, | 2013-05-21 02:41:13 AdminMessage: S,STATS,,,,,1,0,0,0,,,Not Connected,5.0.0.11,,0,0,,0.09,0.09,, | 2013-05-21 02:41:14 AdminMessage: S,STATS,66.112.148.114,60003,500,,1,0,0,0,,,Not Connected,5.0.0.11,410076,0,0,,0.15,0.08,, | 2013-05-21 02:41:15 AdminMessage: S,STATS,66.112.148.114,60003,500,0,1,0,0,0,May 21 2:41AM,May 21 2:41AM,Connected,5.0.0.11,410076,0.06,0.02,0,0.24,0.08,0, | 2013-05-21 02:41:16 IQ Feed: Connecting to Level 1 port 5009 | 2013-05-21 02:41:16 The network socket is connected. | 2013-05-21 02:41:16 IQ Feed: Connected to Level 1 port. | 2013-05-21 02:41:16 IQ Feed: Connecting to Lookup port 9100 | 2013-05-21 02:41:16 IQ Feed: Connecting to Level 2 port (9200)... | 2013-05-21 02:41:16 The network socket is connected. | 2013-05-21 02:41:16 IQ Feed: Connected to Lookup port. | 2013-05-21 02:41:16 IQ Feed: Fully connected. | 2013-05-21 02:41:16 The network socket is connected. | 2013-05-21 02:41:16 IQ Feed: Connected to Level 2 port. | 2013-05-21 02:41:16 IQFeed Level 2 error: Account not authorized for Level II | 2013-05-21 02:41:16 IQ Feed: Disconnected from Level 2 port. | 2013-05-21 02:41:16 c_StreamBuffer::Remove: Trying to remove more data (40 bytes) than the buffer contains (0 bytes). This indicates there is a programming error. | 2013-05-21 02:41:16 |
[2013-05-21 06:50:10] |
The line that indicates a "programming error", will be resolved. However, it is harmless.
