Date/Time: Sun, 08 Sep 2024 00:41:20 +0000
5 min chart showing one bar.
View Count: 884
[2014-12-16 14:36:12] |
bluegrassnash - Posts: 2 |
I have a 5 min chart that is showing the wrong data. The 12-15 has 1 bar showing. Today's date shows 5 min increments. All the trend lines and text appear to be squeezed together. The time frame before yesterday shows as 0:00. I've confirmed that I do not have the zoom in function turned on. The ATR is showing 142.86 and it should be something between 2-6. |
Private File |
[2014-12-17 04:22:27] |
The only way we can help with this is as follows: Remove all studies from the chart. Re-download the data in the chart with Edit >Delete All Data and Download. Refer to help topic 7: https://www.sierrachart.com/index.php?page=doc/helpdetails7.html Unlock the fill space with Chart >> Lock Fill Space. Otherwise, whatever the cause of the problem is, you need to determine that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-17 04:24:53
[2014-12-17 17:36:50] |
I tried deleting the data and that didn't resolve the issue. I removed the chart and created a new one. Thanks.
