Date/Time: Mon, 21 Sep 2026 07:55:38 +0000
FOOTPRINT ONLY SHOWING ZERO'S
View Count: 3805
[2013-05-20 15:37:42]
User57124 - Posts: 48
today I paid for Sierra chart prior I was running a free version(software V976)... Only my first bar footprint after paying and restarting is showing volume numbers all prior is showing zero's ???
what do I need to change so prior history volume will plot in footprints looking left on my screen
thx in advance
Date Time Of Last Edit: 2013-05-20 15:38:44
[2013-05-20 16:48:17]
Please follow the instructions here:
http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php
Date Time Of Last Edit: 2013-10-23 21:16:25
[2013-10-23 20:57:05]
User99360 - Posts: 5
i have a similar problem. I am using the Numbers Bars Study and the trial Version of serria chart.
my Charts on ES, DAX etc are also showing zeros. The AUDCHF chart is display correctly. If I use only Volume it does work. If I switch die Bid Vol x Ask Vol I get the zeros
Best Regards
Andi
[2013-10-23 23:35:54]
This is explained at the bottom of this page here:
https://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php#HistoricalBidAskVolume
It has to do with the historical data from the service being used.
[2013-10-24 08:05:11]
I red that topic, biut I still get it not to work. I tried it wirth the SC Historical Intraday Futures Data and the SC Historical data feed. I also loaded new with "Edit Downlaod Data" but I still see the zeros
Best Regards
[2013-10-24 09:43:39]
Use the service named "SC Historical Intraday Futures Data".
After switching to that service you need to re-download the data for the symbol with Edit >> Delete All Data and Download.
[2013-10-24 15:40:18]
I tried the "SC Historical Intraday Futures Data" data feed. After I performed the "Edit >> Delete All Data and Download" I just see a black window in the Chart.
Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ES#.scid | 2013-10-24 15:38:17
HD Request # 12 - Downloading Intraday chart data for ES# to the file ES#.scid. Service: scsrv | 2013-10-24 15:38:18
HD Request # 12 - Using server: ds4.sierracharts.com port 10049 | 2013-10-24 15:38:18
Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-10-24 15:38:18
The network socket is connected. | 2013-10-24 15:38:18
HD Request # 12 - Requesting up to 7 days of Intraday data. | 2013-10-24 15:38:18
HD Request # 12 - Decompressing data. | 2013-10-24 15:38:18
Socket closed. No error. | 2013-10-24 15:38:18
HD Request # 12 - Server does not have data for the symbol ES# | 2013-10-24 15:38:18
HD Request # 12 - Received 0 records and wrote 0 records for ES# | 2013-10-24 15:38:18
HD Request # 12 - Intraday download COMPLETE for ES# | 2013-10-24 15:38:18
Real-time intraday chart data file updates started for ES# | 2013-10-24 15:38:18
[2013-10-24 16:08:59]
Sierra Chart - Max - Posts: 5968
You will need to change the symbol to ESZ3, please follow the instructions here:
https://www.sierrachart.com/index.php?l=doc/doc_SwitchingSymbols.html#ChangingChartSymbol
Sierra Chart Support
