Date/Time: Sat, 21 Dec 2024 16:16:22 +0000
Volume by Price from a date
View Count: 853
[2014-12-15 05:01:02] |
User308407 - Posts: 1 |
Good day, I'm trying to overlay a Volume by Price study from a date. I've input the start date (2014/01/01) and start time but the chart continues to calculate volume profile only with the information visible on the chart itself. I've attempted numerous different dates and start times with the same result. I'm running SC 1169, how can I correct this? |
[2014-12-15 09:02:44] |
You need to set the Volume Graph Period Type to From Start Date-Time to End.
