Date/Time: Mon, 28 Sep 2026 09:19:46 +0000
Time lagging in replay
View Count: 1756
| [2014-12-14 19:17:49] |
| User57431 - Posts: 31 |
Hello, today I have problem with time lagging in replay. I am replaying several charts together in one chartbook. Each chart has the study CountDown Timer enabled. Unfortunately there is difference between each chart several seconds - that is one problem and the second one is that by replaying by speed 1 the time is not going step by step (second by second) but in intervals (let´say 8-10 seconds intervals). It is a big problem, pls. let me know. |
| [2014-12-14 20:53:32] |
Make sure you have a tick by tick data configuration: http://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php If that does not help, do you see a [M] after the symbol at the top of the chart indicating that the Sierra Chart Exchange Data Feed is being used. If not, that is the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-12-14 21:16:26] |
Hello, I am sure to have a tick by tick data configuration and also pay extra fee for tick data Sierra Chart Exchange Data Feed. Below I am attaching screenshot with different time on it . Hope you can see it as I cannot check the screenshot. http://www.sierrachart.com/image.php?l=1418591523244.png |
| [2014-12-14 22:13:44] |
It is not unusual to have different Countdown Timer remaining times. The only practical problem we can help with, is to ensure you have complete tick by tick data in the Intraday data file. Go to one of the charts and re-download the data with Edit >> Delete All Data Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
