Date/Time: Thu, 28 Mar 2024 11:36:28 +0000
SC DOM
View Count: 1796
[2013-05-20 13:20:13] |
User25261 - Posts: 24 |
HI, Can you please help me to get the same DOM setting (look at the attached)? How i get the volume size showed in the left of the DOM(look at the attached)? Adam |
Attachment Deleted. SC dom.png / V - Attached On 2013-05-20 13:19:56 UTC - Size: 78.29 KB - 670 views |
[2013-05-20 21:26:07] |
User45685 - Posts: 36 |
How exactly did they manage to include the time & sales into the dom?
[2013-05-20 22:09:52] |
ITS NOT MY DOM.I FOUND IT IN SOME FORUM AND I WANT TO GET LIKE IT,THATS WHY I ASK YOU
[2013-05-21 00:53:04] |
Please refer to these 2 sections of the Chart Trading page: http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#CustomizingGraphics http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#TradeDOMVolumeProfile To get the Time and Sales window on the Trade DOM, you just need to open it from the Chart menu and position it where you want. It is not attached to it, it just floats above the Trade DOM. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
