Date/Time: Sat, 26 Sep 2026 17:44:27 +0000
how do i create a alert on a indicator>?
View Count: 1244
| [2014-12-12 17:26:28] |
| User48557 - Posts: 138 |
I would like to have a alert that beeps when i get a volume bar of 200 or more on a 10 second chart using nasdaq. Can this be accomplished?
| [2014-12-17 22:33:16] |
| [2014-12-18 00:11:09] |
| Sawtooth - Posts: 4354 |
1) Using an internet browser, go here: www.sierrachart.com 2) Type 'alerts' in the Search bar in the upper right corner, press Enter. 3) Click on the top Result link for the documentation on alerts Post here again if you need more help. |
| [2014-12-18 01:45:54] |
This had gotten overlooked. The formula for this is : SG1 > 200 Use this on the Volume study. Here is the documentation: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html#EnterAlertOnStudy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
