Date/Time: Sun, 08 Sep 2024 00:45:48 +0000
Color Heikin-Ashi Bars Based on Alert
View Count: 1181
[2014-12-12 05:17:28] |
apollofl - Posts: 95 |
The Alert isn't painting the bars, but is showing OHLC regular bars on top of Heikin-Ashi bars with the color. Help...How do I paint the Heikin-Ashi Bars? Thanks |
[2014-12-12 09:21:30] |
What is the study you are using the color the bars?
[2014-12-12 11:49:36] |
Color Bar Based On Alert.
[2014-12-17 23:15:09] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
