Date/Time: Sat, 13 Sep 2025 04:29:17 +0000
[User Discussion] - to write in Russian in Type Text Tool
View Count: 1856
[2014-12-12 04:04:06] |
User99728 - Posts: 9 |
Hi, tell me how to write in Russian in Type Text Tool http://www.sierrachart.com/image.php?l=1418357031613.png |
[2014-12-12 08:12:27] |
Sierra Chart does not currently support Cyrillic for text on the charts. Although if you change to a font in the chart that has Cyrillic, it might work assuming the characters are a single byte each. You can change the font through Global Settings >> Graphics Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-12 19:14:01] |
ganz - Posts: 1048 |
User99728 http://sc.ucoz.co.uk/forum/4-2-1880-16-1384246103 |
[2014-12-12 22:42:10] |
WarEagle - Posts: 79 |
Are there any plans to allow multibyte characters? I would like to use various symbols for short names in indicators or to draw text on the chart. For example: 'σ' shows as 's' while other characters only get a '?' in their place. I was receiving an error message in Visual Studio that I could not figure out until I realized only single byte characters were supported. Thanks |
[2014-12-13 16:18:17] |
2_Ganz I've tried it, but it did not work in my case :( https://www.dropbox.com/s/p4ez899szalkukj/000.PNG?dl=0 https://www.dropbox.com/s/6m3z8qu30e2nlpu/001.PNG?dl=0 |
[2014-12-13 21:02:54] |
User99728 На srv2008r2 и в линуксе нормально работает - проверил на 1216 http://s7.postimg.org/cqyszj6qj/rus1.png у Вас там даже "начертание" в настройках шрифта кракозябрами - большой привет от M$ :) |
[2014-12-14 06:02:13] |
2_ganz Простите, не имею иной возможности с вами связаться, и поэтому пишу здесь, народ жалуется что невозможно зарегистрироваться у Вас на форуме, все спотыкаются о поле введения аватара, если это не ваша целенаправленная политика, поправьте пожалуйста. |
[2014-12-14 06:19:09] |
User99728 хостинг того форума дырявый и там нет пока другой возможности защиты от ботов. всё что нужно - это аватар. хотя, имхо, в регистрации нет особого смысла, тк что касается СЧ - всё доступно без регистрации. читайте свободно. невозможно зарегистрироваться
это определенно не так, ибо только вчера человек зарегистрировался.малэнкий картинко - не такой балшой проблема подобрать. :) удачи в делах. Date Time Of Last Edit: 2014-12-14 06:19:36
[2014-12-20 18:16:03] |
User99728 не знаю как соотносятся вопрос на пауке и здесь, но почти все индкюи с форума доступны тут, включая исходники https://www.sierrachart.com/supportboard/showthread.php?t=37616 |
