Date/Time: Sun, 22 Dec 2024 06:11:02 +0000
Ray Tool Movement
View Count: 859
[2014-12-11 16:43:48]
William C Midgley - Posts: 2
I'm using the most recent sierra chart version.
I use the ray tool often by anchoring it to 2 price points on the chart so the ray extends out as possible future support or resistance.
However, I notice that despite the ray being anchored, the projected line will occasionally move so that the accuracy of where the future support/resistance line should be is gone.
Are you aware of this issue & how can it be corrected or worked around?
[2014-12-11 17:20:21]
Refer to this help topic:
https://www.sierrachart.com/index.php?page=doc/helpdetails34.html
