Date/Time: Sun, 22 Dec 2024 06:28:19 +0000
order action source question
View Count: 834
[2014-12-10 23:15:52] |
onnb - Posts: 662 |
ZBH5-CBOT 5 Min #8 | User order entry | Last: 143.25 the above line is from Trade Activity Log under the "OrderActionSource" column. Does this mean that order was submitted from SC ui? |
[2014-12-11 02:48:58] |
Yes.
