Date/Time: Thu, 10 Sep 2026 15:58:47 +0000
gdt candlestick bar hiding
View Count: 2385
| [2014-12-10 22:53:28] |
| onnb - Posts: 666 |
I have a chart with sc.GraphDrawType = GDT_CANDLESTICK; I am trying to hide (not display) the last bar while its forming and only display on bar close. I am trying to do this by changing the primary color of the Open/High/Low/Last Subgraphs to the chart background color. This does hide the last bar but messes up all the rest of the bars by painting them black (I have a white background). 1. Do you have another approach to hiding this bar? 2. Any idea why the rest of the bars might be black? below is the set default block if (sc.SetDefaults) { sc.GraphName = "My Study"; sc.FreeDLL = 1; sc.MaintainAdditionalChartDataArrays = 1; sc.AutoLoop = 0; sc.ValueFormat = 0; sc.GraphDrawType = GDT_CANDLESTICK; Open.Name = "Open"; Open.DrawStyle = DRAWSTYLE_LINE; Open.PrimaryColor = RGB(0, 255, 0); Open.SecondaryColor = RGB(0, 255, 0); Open.SecondaryColorUsed = true; Open.DrawZeros = true; High.Name = "High"; High.DrawStyle = DRAWSTYLE_LINE; High.PrimaryColor = RGB(0, 128, 0); High.DrawZeros = true; Low.Name = "Low"; Low.DrawStyle = DRAWSTYLE_LINE; Low.PrimaryColor = RGB(255, 0, 0); Low.SecondaryColor = RGB(255, 0, 0); Low.SecondaryColorUsed = true; Low.DrawZeros = true; Close.Name = "Close"; Close.DrawStyle = DRAWSTYLE_LINE; Close.PrimaryColor = RGB(128, 0, 0); Close.DrawZeros = true; OHLCAvg.Name = "OHLC Avg"; OHLCAvg.DrawStyle = DRAWSTYLE_IGNORE; OHLCAvg.PrimaryColor = COLOR_GREEN; OHLCAvg.DrawZeros = true; HLCAvg.Name = "HLC Avg"; HLCAvg.DrawStyle = DRAWSTYLE_IGNORE; HLCAvg.PrimaryColor = COLOR_GREEN; HLCAvg.DrawZeros = true; HLAvg.Name = "HL Avg"; HLAvg.DrawStyle = DRAWSTYLE_IGNORE; HLAvg.PrimaryColor = COLOR_GREEN; HLAvg.DrawZeros = true; return; } |
| [2014-12-11 18:57:57] |
| onnb - Posts: 666 |
consider this issue resolved
| [2014-12-11 19:07:31] |
Use the Color Bar Draw Style, set its color to black, and set the Subgraph element for it at the last bar to 1.
