Date/Time: Fri, 22 Nov 2024 13:55:18 +0000
[User Discussion] - volume profile
View Count: 2068
[2013-05-20 06:14:16]
norvik - Posts: 22
help me!
I want to have my profile shows the volume of all levels. Why is not there a function for this indicator? In what way can I read the entire volume? I showed my question is in the picture.
imageqwestion to sch.jpg / V - Attached On 2013-05-20 06:08:54 UTC - Size: 230.1 KB - 617 views
[2013-05-20 22:09:22]
Make sure in the Volume by Price study settings that the Ticks per Volume Bar input is set to 1.
[2013-05-21 18:07:15]
norvik - Posts: 22
Excuse me, but you did not answer my question.
I ask you, as an indicator can show the volume of the entire profile, rather than a specific level.
Please look at the picture. I explained everything in detail.
imageqwestion to sch.jpg / V - Attached On 2013-05-21 18:06:59 UTC - Size: 230.1 KB - 640 views
[2013-05-21 18:22:41]
M5amhan - Posts: 468
set the Ticks per Volume Bar to an outrageous number like 10000 so every tick in the current session will be accounted for in one level.. the larger the time frame the larger that number will need to be
[2013-05-21 19:41:20]
norvik - Posts: 22
Thank you very much for your answer, the user 51479. This is an extreme option. I would like to see a better solution. This I expect from the technical support team.
[2013-05-21 20:10:42]
well it is not clear what you are trying to do
do you want the profile to look the same as is and also label the volume for the whole thing?
also this is labeled a user discussion so it is likely they wont view this again
[2013-05-21 20:17:23]
this is the best i can do if that is what you are looking for, of course the visible profile can be customized how you like it and you can lock the fill space so the bars wont overlap the numbers.. i can just send this as a study collection through the forum if you want it
Date Time Of Last Edit: 2013-05-21 20:19:36
imageCL.PNG / V - Attached On 2013-05-21 20:16:59 UTC - Size: 17.1 KB - 589 views
[2013-05-21 20:25:32]
norvik - Posts: 22
regard User51479, you write: do you want the profile to look the same as is and also label the volume for the whole thing? - Yes, I want to achieve it.
[2013-05-21 20:28:51]
there it is, all you have to do is unlock your fill space (if its locked) move the bars over so they dont overlap then lock it. and customize your profile
forgot to add put this in the data file in your sierra chart folder located in my computer > local disk C (or wherever you have it installed)
Date Time Of Last Edit: 2013-05-21 20:32:26
attachmentVolProfileTotalVol.StdyCollct - Attached On 2013-05-21 20:27:25 UTC - Size: 15.25 KB - 747 views
[2013-05-21 20:33:49]
norvik - Posts: 22
Regard User51479! I thank you for your support!
