Date/Time: Tue, 23 Apr 2024 17:08:27 +0000
[User Discussion] - Flatten Working Order
View Count: 1677
[2013-05-19 23:50:32] |
Richard Reyes - Posts: 98 |
I am running an automated trading system and I have been using Excel Cell "J29" ("Flatten And Cancel Working Orders") to flatten a current trading position. My question is, is there something that I can do to not only cancel the position, but also simultaneously reversing the position?
[2013-05-20 21:44:00] |
Look at the SupportReversals option in the Automated Trading Management documentation page.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-20 21:44:15
[2013-05-21 14:08:33] |
This does not appear to address my problem. I am using the "Spreadsheet System for Trading" (Excel formulas). I am using cell "J29" (Flatten and Cancel Working Orders) to stop a losing trade at a certain dollar amount (J10>(-xxxxx)). I would like to not only flatten the order using cell "J29" (J10>(-xxxxx)), when a trade is losing a specific amount of money (xxxxx), but to also simultaneously reverse that trade. I find no solution addressing my specific problem. Is there some function that I can incorporate into my Excel formulas (cells K, L, M, and N) orsome trade function "box" that I can check? Many, many thanks
