Date/Time: Sat, 21 Dec 2024 12:55:47 +0000
Sierrchat is slow 3-8 seconds compared to AT/Trasact DOM right now
View Count: 1321
[2014-12-08 15:33:16] |
User29582 - Posts: 33 |
WHY?????????????????????????
[2014-12-08 15:41:45] |
Does anyone get the same issues
[2014-12-08 16:08:44] |
It's still delayed a few seconds 11:08 AM EST
[2014-12-08 16:39:21] |
This issue is not within the scope of our support. You will need to contact the provider of the data feed which is TransAct. Have your broker put you in contact TransAct support. Refer to help topic 4 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails4.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-08 16:39:31
