Date/Time: Sat, 21 Dec 2024 13:12:06 +0000
Changing Tick Size on FX Numbers Bars
View Count: 1151
[2014-12-08 13:05:54]
Halco - Posts: 92
Sorry if this is a dumb question but I'm very new to this: Is it ok to change the tick size of, for instance, the GBPUSD from 0.00005 to 0.0001 on a numbers bars chart to filter out some noise and also make the bars easier to see on the chart? Or would this somehow result in inaccurate numbers bars? Thanks.
Date Time Of Last Edit: 2014-12-08 13:06:35
[2014-12-08 18:30:13]
This is perfectly fine and is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#AdjustingTickSizeForLargerIncrement
