Date/Time: Sun, 08 Sep 2024 00:00:15 +0000
Encountered Improper Argument Error
View Count: 1210
[2014-12-07 22:04:06] |
C. Notes - Posts: 129 |
Hi, I am using a session with many charts, and 12 charts with spreadsheets. I keep running into an improper argument error. This happens with both old and new versions of SC (CLR) The program crashes, when I try and change settings the window opens wide and blank on the screen. I've had this happen quite a bit with larger sessions under many different circumstances. Cheers |
[2014-12-07 22:07:44] |
We are not clear about exactly what you are doing when you see this error and specifically in relation to what window? Also if the root of the problem has something to do with the CLR Spreadsheets we cannot resolve that. Development of those has ceased and we only support the New Spreadsheets now. Refer to: Differences Between New Spreadsheets and Old Spreadsheets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
