Date/Time: Fri, 18 Sep 2026 04:52:44 +0000
New spreadsheet syntax
View Count: 1391
[2014-12-07 06:52:23]
enemyspy - Posts: 307
I am looking for an alternative way to accomplish the following excel syntax formula within the syntax of the new sierra spreadsheets:
=SUM(INDIRECT(ADDRESS(MATCH(1.001,SHEET1!$BO$1:BO20000,0),310,4,TRUE,"SHEET2")):INDIRECT(ADDRESS(MATCH(2,SHEET1!BO1:BO20000,1),310,4,TRUE)))
or more simply
sum( address("defines first half of range on other sheet) : address("defines second half of range on other sheet)
Currently unable to define a range using address function. Is there another way to do this?
[2014-12-07 22:28:15]
We will work on adding a two-part ADDRESS function which will return a range reference.
