Date/Time: Sat, 21 Dec 2024 13:00:15 +0000
Flex Renko Settings
View Count: 1494
[2014-12-06 20:47:10] |
User121729 - Posts: 37 |
I want to set up a 2-0-6 Flex Renko Bar with wicks but it will not accept those numbers. This can be doen with NT UniRenko. Is there a way I can do this with SC? Thx |
[2014-12-08 12:56:56] |
User13668 - Posts: 294 |
Here is one of my charts using 4-0-4 which shows wicks. Are your chart settings configured like mine? |
FlexRenkoCapture.PNG / V - Attached On 2014-12-08 12:56:30 UTC - Size: 94.09 KB - 508 views |
[2014-12-08 16:51:19] |
This is not supported: Note: Reversal Offset must be greater than or equal to zero and less than the Brick Size.
