Date/Time: Wed, 24 Apr 2024 04:56:38 +0000
spreadsheet can do auto trading if cross Rectangle (market if to
View Count: 1639
[2013-05-19 17:17:15] |
tomy - Posts: 5 |
spreadsheet can do auto trading if cross Rectangle (market if touched) ?? can i get help to setup this ? thank you . |
[2013-05-19 21:36:56] |
Do you mean a Rectangle that you drew on the chart?
[2013-05-20 09:33:40] |
tomy - Posts: 5 |
Yes,Rectangle that i drew on the chart. only in first touch (one time market if touch if it cross the Rectangle that i drew on the chart) |
[2013-05-20 09:36:37] |
This is not supported.
[2013-05-20 10:03:57] |
tomy - Posts: 5 |
can you do when we drewing Rectangle on the chart it will be place on the studie list (like the Volume profile ..) this way it's easy can be support by spreadsheet on even c++ (i thing it's good even for line when it cross) so if we will like to drew levels that enter a trade automatic that will be easy to setup .. that is basic. :-) Date Time Of Last Edit: 2013-05-20 10:04:48
