Date/Time: Sat, 21 Dec 2024 12:48:32 +0000
Delete Drawing?
View Count: 1713
[2014-12-06 16:36:35] |
User623839 - Posts: 108 |
What happened to being able to erase ALL text AND drawings without having to hit "OK" in the confirmation pop up window? Seems cumbersome to have to confirm every time... |
[2014-12-06 20:34:59] |
Global Settings >> Tool Settings >> Prompt When Deleting All Chart Drawings
[2014-12-07 02:47:27] |
BAM! Thanks:)
