Date/Time: Sat, 21 Dec 2024 13:19:53 +0000
Tools
View Count: 876
[2014-12-06 00:43:09] |
BDS City Group LTD - Posts: 4 |
Hi, When analysis the charts I currently use a hand tool that enables me to drag the chart horizontally which is perfect. I would also like to be able to drag vertically to position the chart exactly where I want it in my screen. I know this can be done and want to know what settings I need to set to enable this. Thanks, Ben |
[2014-12-06 01:49:37] |
This is documented in this section here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Hand Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
