Date/Time: Wed, 05 Feb 2025 14:04:20 +0000
Time lines
View Count: 828
[2014-12-05 22:50:52] |
navigator - Posts: 27 |
On a range bar chart, is there a way to have vertical lines drawn on the chart at a certain specified period. For example at every 30 min interval? Thanks
[2014-12-06 01:47:16] |
Yes. Refer to the Vertical Grid: https://www.sierrachart.com/index.php?page=doc/doc_ChartMenu.html#Vgrid Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
