Date/Time: Sat, 21 Dec 2024 13:20:02 +0000
exporting chart header data
View Count: 1022
[2014-12-05 22:04:07]
nioko54130 - Posts: 108
Hi Support!
Do you know if i could export the chart header data ( for example %dailynet change ) to my intraday chart.
In fact, i would like to know if it exist a studie which could provide the %dailynet in order to see the % evolution of the price action.
thank's
[2014-12-07 13:00:38]
No body knows how can i get this simple features on my footprint chart?
[2014-12-07 13:08:51]
i notice that this kind of statistics already exists on the quote board, but not on the studies system..
It's too bad that we can't use this as a studie
I have tryed to use "price percentage oscillator" and "change since open" but it is not what i am looking for
I just want a studie which looks like : change from the high, or change from the low ; or change from the extrem point of the range.
It would be not too hard to do?
[2014-12-07 15:16:07]
issue solved
[2014-12-08 08:42:04]
Through Global Settings >>Customize Chart Header, you can add the Daily Net Change Percent field.
