Date/Time: Wed, 05 Feb 2025 09:45:08 +0000
No Market Stats
View Count: 944
[2014-12-04 14:32:53] |
startledbymoth - Posts: 39 |
Again I have no Market Stats. Why is this? Last time it was Rithmic. This is a big mistake and too frequent. Please advise.
[2014-12-04 14:48:13] |
never mind. I understand it's your historicals and you're aware. Sorry. |
[2014-12-04 17:51:21] |
We do not see a problem with the market statistics data feed. What is the symbol you are having a problem with?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-04 18:05:12
[2014-12-04 18:04:58] |
The historical data problem is now solved. This problem is now solved. Refer to these instructions to re-download the data: http://www.sierrachart.com/index.php?page=doc/helpdetails7.html#RetryDownloadDataInChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
