Date/Time: Wed, 05 Feb 2025 09:45:47 +0000
Problem with data
View Count: 1229
[2014-12-03 22:19:32] |
User57111 - Posts: 25 |
Hi, my data on Daily, Weekly and Monthly chart do not update! Intraday data are OK. Recently I had to install Version 1203 because of some problem with data what happen now? Please help. Best Regards, Rafal |
[2014-12-03 22:44:20] |
Refer to help topic 6: Http://www.sierrachart.com/index.php?page=doc/helpdetails6.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
