Date/Time: Thu, 10 Sep 2026 09:34:12 +0000
Open E Cry - Waiting to Reconnect
View Count: 1309
| [2014-12-03 17:17:58] |
| User847587 - Posts: 23 |
Software version: 1214 | 2014-12-03 12:05:53 Uses New Spreadsheets | 2014-12-03 12:05:53 Usage end date: 2014-12-16 | 2014-12-03 12:05:53 Enabled for: Advanced Features. | 2014-12-03 12:05:53 Enabled for: Sierra Chart Historical Data Service. | 2014-12-03 12:05:53 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-12-03 12:05:53 Active service: SC Historical Data | 2014-12-03 12:05:53 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-12-03 12:05:53 2014-12-03 12:05:53 Local computer clock time | 2014-12-03 12:05:53 2014-12-03 17:05:53 GMT time | 2014-12-03 12:05:53 2014-12-03 12:05:53 Time zone adjusted time | 2014-12-03 12:05:53 Time difference to server time: 5 seconds. | 2014-12-03 12:05:53 Program path: C:\SierraChart\ | 2014-12-03 12:05:53 Data Files path: C:\SierraChart\Data\ | 2014-12-03 12:05:53 OS Version Number: 6.2 | 2014-12-03 12:05:53 Locale Information: C | 2014-12-03 12:05:53 Checking for new symbol settings for ddf | 2014-12-03 12:05:53 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-12-03 12:05:53 HTTP connection to www.sierrachart.com:80 (1092) | Connected. | 2014-12-03 12:05:53 Symbol settings are up-to-date for ddf | 2014-12-03 12:05:53 SC Historical Data | Connected. Historical Intraday data will be requested. | 2014-12-03 12:05:58 HTTP connection to www.sierrachart.com:80 (1092) | Closed. No error. | 2014-12-03 12:06:03 HTTP connection to www.sierrachart.com:80 (1092) | Shutdown and closed. | 2014-12-03 12:06:03 Current selected Data/Trading service: Open E Cry FIX | 2014-12-03 12:06:08 Checking for new symbol settings for oec | 2014-12-03 12:06:08 SC Historical Data | Disconnected | 2014-12-03 12:06:08 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:06:08 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-12-03 12:06:08 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:06:08 HTTP connection to www.sierrachart.com:80 (1112) | Connected. | 2014-12-03 12:06:10 OEC FIX Trading socket (1760) | Connected. | 2014-12-03 12:06:10 OEC FIX Trading socket (1760) | Starting SSL connection. | 2014-12-03 12:06:10 Requesting symbol settings for oec. Overwrite = on. | 2014-12-03 12:06:11 OEC FIX Trading socket (1760) | SSL connection established. | 2014-12-03 12:06:12 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:06:12 OEC FIX Trading socket (1760) | Closed. No error. | 2014-12-03 12:06:12 OEC FIX Trading socket (1760) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:06:12 OEC FIX Trading socket (1760) | SSL has been shut down. | 2014-12-03 12:06:12 OEC FIX Trading socket (1760) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:06:12 OEC FIX Trading socket (1760) | Shutdown and closed. | 2014-12-03 12:06:12 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:06:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:06:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:06:12 Disconnected from Open E Cry. | 2014-12-03 12:06:12 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:06:12 Symbol settings received. | 2014-12-03 12:06:13 Processed received symbol settings | 2014-12-03 12:06:13 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:06:15 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:06:15 OEC FIX Trading socket (1760) | Connected. | 2014-12-03 12:06:15 OEC FIX Trading socket (1760) | Starting SSL connection. | 2014-12-03 12:06:15 OEC FIX Trading socket (1760) | SSL connection established. | 2014-12-03 12:06:16 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:06:16 OEC FIX Trading socket (1760) | Closed. No error. | 2014-12-03 12:06:16 OEC FIX Trading socket (1760) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:06:16 OEC FIX Trading socket (1760) | SSL has been shut down. | 2014-12-03 12:06:16 OEC FIX Trading socket (1760) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:06:16 OEC FIX Trading socket (1760) | Shutdown and closed. | 2014-12-03 12:06:16 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:06:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:06:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:06:16 Disconnected from Open E Cry. | 2014-12-03 12:06:16 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:06:16 HTTP connection to www.sierrachart.com:80 (1112) | Closed. No error. | 2014-12-03 12:06:18 HTTP connection to www.sierrachart.com:80 (1112) | Shutdown and closed. | 2014-12-03 12:06:18 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:06:19 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:06:19 OEC FIX Trading socket (444) | Connected. | 2014-12-03 12:06:20 OEC FIX Trading socket (444) | Starting SSL connection. | 2014-12-03 12:06:20 OEC FIX Trading socket (444) | SSL connection established. | 2014-12-03 12:06:20 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:06:20 OEC FIX Trading socket (444) | Closed. No error. | 2014-12-03 12:06:21 OEC FIX Trading socket (444) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:06:21 OEC FIX Trading socket (444) | SSL has been shut down. | 2014-12-03 12:06:21 OEC FIX Trading socket (444) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:06:21 OEC FIX Trading socket (444) | Shutdown and closed. | 2014-12-03 12:06:21 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:06:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:06:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:06:21 Disconnected from Open E Cry. | 2014-12-03 12:06:21 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:06:21 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:06:24 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:06:24 OEC FIX Trading socket (2016) | Connected. | 2014-12-03 12:06:24 OEC FIX Trading socket (2016) | Starting SSL connection. | 2014-12-03 12:06:24 OEC FIX Trading socket (2016) | SSL connection established. | 2014-12-03 12:06:24 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:06:25 OEC FIX Trading socket (2016) | Closed. No error. | 2014-12-03 12:06:25 OEC FIX Trading socket (2016) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:06:25 OEC FIX Trading socket (2016) | SSL has been shut down. | 2014-12-03 12:06:25 OEC FIX Trading socket (2016) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:06:25 OEC FIX Trading socket (2016) | Shutdown and closed. | 2014-12-03 12:06:25 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:06:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:06:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:06:25 Disconnected from Open E Cry. | 2014-12-03 12:06:25 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:06:25 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:06:28 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:06:28 OEC FIX Trading socket (2016) | Connected. | 2014-12-03 12:06:28 OEC FIX Trading socket (2016) | Starting SSL connection. | 2014-12-03 12:06:28 OEC FIX Trading socket (2016) | SSL connection established. | 2014-12-03 12:06:29 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:06:29 OEC FIX Trading socket (2016) | Closed. No error. | 2014-12-03 12:06:29 OEC FIX Trading socket (2016) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:06:29 OEC FIX Trading socket (2016) | SSL has been shut down. | 2014-12-03 12:06:29 OEC FIX Trading socket (2016) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:06:29 OEC FIX Trading socket (2016) | Shutdown and closed. | 2014-12-03 12:06:29 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:06:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:06:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:06:29 Disconnected from Open E Cry. | 2014-12-03 12:06:29 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:06:29 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:06:32 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:06:32 OEC FIX Trading socket (2016) | Connected. | 2014-12-03 12:06:33 OEC FIX Trading socket (2016) | Starting SSL connection. | 2014-12-03 12:06:33 OEC FIX Trading socket (2016) | SSL connection established. | 2014-12-03 12:06:34 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:06:34 OEC FIX Trading socket (2016) | Closed. No error. | 2014-12-03 12:06:34 OEC FIX Trading socket (2016) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:06:34 OEC FIX Trading socket (2016) | SSL has been shut down. | 2014-12-03 12:06:34 OEC FIX Trading socket (2016) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:06:34 OEC FIX Trading socket (2016) | Shutdown and closed. | 2014-12-03 12:06:34 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:06:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:06:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:06:34 Disconnected from Open E Cry. | 2014-12-03 12:06:34 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:06:34 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:06:37 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:06:37 OEC FIX Trading socket (1896) | Connected. | 2014-12-03 12:06:38 OEC FIX Trading socket (1896) | Starting SSL connection. | 2014-12-03 12:06:38 OEC FIX Trading socket (1896) | SSL connection established. | 2014-12-03 12:06:38 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:06:38 OEC FIX Trading socket (1896) | Closed. No error. | 2014-12-03 12:06:39 OEC FIX Trading socket (1896) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:06:39 OEC FIX Trading socket (1896) | SSL has been shut down. | 2014-12-03 12:06:39 OEC FIX Trading socket (1896) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:06:39 OEC FIX Trading socket (1896) | Shutdown and closed. | 2014-12-03 12:06:39 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:06:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:06:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:06:39 Disconnected from Open E Cry. | 2014-12-03 12:06:39 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:06:39 File >> Disconnect selected. | 2014-12-03 12:06:41 Disconnected from Open E Cry. | 2014-12-03 12:06:41 Current selected Data/Trading service: SC Historical Data | 2014-12-03 12:06:53 Checking for new symbol settings for ddf | 2014-12-03 12:06:53 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-12-03 12:06:53 HTTP connection to www.sierrachart.com:80 (1920) | Connected. | 2014-12-03 12:06:53 Requesting symbol settings for ddf. Overwrite = on. | 2014-12-03 12:06:54 Symbol settings received. | 2014-12-03 12:06:58 Processed received symbol settings | 2014-12-03 12:06:59 HTTP connection to www.sierrachart.com:80 (1920) | Closed. No error. | 2014-12-03 12:07:06 HTTP connection to www.sierrachart.com:80 (1920) | Shutdown and closed. | 2014-12-03 12:07:06 Current selected Data/Trading service: Open E Cry FIX | 2014-12-03 12:08:41 Checking for new symbol settings for oec | 2014-12-03 12:08:41 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-12-03 12:08:41 HTTP connection to www.sierrachart.com:80 (1896) | Connected. | 2014-12-03 12:08:43 Requesting symbol settings for oec. Overwrite = on. | 2014-12-03 12:08:44 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:08:45 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:08:45 OEC FIX Trading socket (788) | Connected. | 2014-12-03 12:08:45 OEC FIX Trading socket (788) | Starting SSL connection. | 2014-12-03 12:08:45 Symbol settings received. | 2014-12-03 12:08:46 Processed received symbol settings | 2014-12-03 12:08:46 OEC FIX Trading socket (788) | SSL connection established. | 2014-12-03 12:08:46 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:08:46 OEC FIX Trading socket (788) | Closed. No error. | 2014-12-03 12:08:46 OEC FIX Trading socket (788) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:08:46 OEC FIX Trading socket (788) | SSL has been shut down. | 2014-12-03 12:08:46 OEC FIX Trading socket (788) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:08:46 OEC FIX Trading socket (788) | Shutdown and closed. | 2014-12-03 12:08:46 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:08:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:08:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:08:46 Disconnected from Open E Cry. | 2014-12-03 12:08:46 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:08:46 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:08:49 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:08:49 OEC FIX Trading socket (788) | Connected. | 2014-12-03 12:08:50 OEC FIX Trading socket (788) | Starting SSL connection. | 2014-12-03 12:08:50 HTTP connection to www.sierrachart.com:80 (1896) | Closed. No error. | 2014-12-03 12:08:51 HTTP connection to www.sierrachart.com:80 (1896) | Shutdown and closed. | 2014-12-03 12:08:51 OEC FIX Trading socket (788) | SSL connection established. | 2014-12-03 12:08:52 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:08:52 OEC FIX Trading socket (788) | Closed. No error. | 2014-12-03 12:08:52 OEC FIX Trading socket (788) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:08:52 OEC FIX Trading socket (788) | SSL has been shut down. | 2014-12-03 12:08:52 OEC FIX Trading socket (788) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:08:52 OEC FIX Trading socket (788) | Shutdown and closed. | 2014-12-03 12:08:52 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:08:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:08:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:08:52 Disconnected from Open E Cry. | 2014-12-03 12:08:52 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:08:52 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:08:55 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:08:55 OEC FIX Trading socket (1824) | Connected. | 2014-12-03 12:08:56 OEC FIX Trading socket (1824) | Starting SSL connection. | 2014-12-03 12:08:56 OEC FIX Trading socket (1824) | SSL connection established. | 2014-12-03 12:08:57 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:08:57 OEC FIX Trading socket (1824) | Closed. No error. | 2014-12-03 12:08:57 OEC FIX Trading socket (1824) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:08:57 OEC FIX Trading socket (1824) | SSL has been shut down. | 2014-12-03 12:08:57 OEC FIX Trading socket (1824) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:08:57 OEC FIX Trading socket (1824) | Shutdown and closed. | 2014-12-03 12:08:57 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:08:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:08:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:08:57 Disconnected from Open E Cry. | 2014-12-03 12:08:58 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:08:58 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:01 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:01 OEC FIX Trading socket (792) | Connected. | 2014-12-03 12:09:01 OEC FIX Trading socket (792) | Starting SSL connection. | 2014-12-03 12:09:01 OEC FIX Trading socket (792) | SSL connection established. | 2014-12-03 12:09:01 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:02 OEC FIX Trading socket (792) | Closed. No error. | 2014-12-03 12:09:02 OEC FIX Trading socket (792) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:02 OEC FIX Trading socket (792) | SSL has been shut down. | 2014-12-03 12:09:02 OEC FIX Trading socket (792) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:02 OEC FIX Trading socket (792) | Shutdown and closed. | 2014-12-03 12:09:02 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:02 Disconnected from Open E Cry. | 2014-12-03 12:09:02 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:02 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:05 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:05 OEC FIX Trading socket (792) | Connected. | 2014-12-03 12:09:05 OEC FIX Trading socket (792) | Starting SSL connection. | 2014-12-03 12:09:05 OEC FIX Trading socket (792) | SSL connection established. | 2014-12-03 12:09:06 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:06 OEC FIX Trading socket (792) | Closed. No error. | 2014-12-03 12:09:06 OEC FIX Trading socket (792) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:06 OEC FIX Trading socket (792) | SSL has been shut down. | 2014-12-03 12:09:06 OEC FIX Trading socket (792) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:06 OEC FIX Trading socket (792) | Shutdown and closed. | 2014-12-03 12:09:06 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:06 Disconnected from Open E Cry. | 2014-12-03 12:09:06 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:06 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:09 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:09 OEC FIX Trading socket (792) | Connected. | 2014-12-03 12:09:09 OEC FIX Trading socket (792) | Starting SSL connection. | 2014-12-03 12:09:09 OEC FIX Trading socket (792) | SSL connection established. | 2014-12-03 12:09:10 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:10 OEC FIX Trading socket (792) | Closed. No error. | 2014-12-03 12:09:10 OEC FIX Trading socket (792) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:10 OEC FIX Trading socket (792) | SSL has been shut down. | 2014-12-03 12:09:10 OEC FIX Trading socket (792) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:10 OEC FIX Trading socket (792) | Shutdown and closed. | 2014-12-03 12:09:10 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:10 Disconnected from Open E Cry. | 2014-12-03 12:09:10 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:10 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:13 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:13 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:09:14 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:09:14 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:09:14 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:14 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:09:14 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:14 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:09:14 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:14 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:09:14 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:14 Disconnected from Open E Cry. | 2014-12-03 12:09:14 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:14 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:17 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:17 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:09:18 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:09:18 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:09:18 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:19 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:09:19 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:19 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:09:19 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:19 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:09:19 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:19 Disconnected from Open E Cry. | 2014-12-03 12:09:19 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:19 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:22 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:22 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:09:23 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:09:23 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:09:25 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:25 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:09:25 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:25 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:09:25 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:25 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:09:25 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:25 Disconnected from Open E Cry. | 2014-12-03 12:09:25 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:25 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:28 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:28 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:09:29 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:09:29 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:09:29 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:29 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:09:30 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:30 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:09:30 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:30 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:09:30 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:30 Disconnected from Open E Cry. | 2014-12-03 12:09:30 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:30 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:33 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:33 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:09:33 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:09:33 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:09:33 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:34 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:09:34 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:34 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:09:34 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:34 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:09:34 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:34 Disconnected from Open E Cry. | 2014-12-03 12:09:34 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:34 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:37 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:37 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:09:37 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:09:37 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:09:38 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:38 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:09:38 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:38 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:09:38 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:38 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:09:38 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:38 Disconnected from Open E Cry. | 2014-12-03 12:09:38 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:38 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:41 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:41 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:09:41 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:09:41 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:09:42 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:43 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:09:43 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:43 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:09:43 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:43 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:09:43 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:43 Disconnected from Open E Cry. | 2014-12-03 12:09:43 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:43 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:46 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:46 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:09:46 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:09:46 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:09:47 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:47 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:09:47 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:47 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:09:47 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:47 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:09:47 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:47 Disconnected from Open E Cry. | 2014-12-03 12:09:47 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:47 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:50 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:50 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:09:50 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:09:50 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:09:51 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:51 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:09:51 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:51 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:09:51 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:51 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:09:51 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:51 Disconnected from Open E Cry. | 2014-12-03 12:09:51 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:51 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:54 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:54 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:09:54 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:09:54 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:09:55 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:55 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:09:55 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:09:55 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:09:55 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:09:55 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:09:55 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:09:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:09:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:09:55 Disconnected from Open E Cry. | 2014-12-03 12:09:55 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:09:55 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:09:58 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:09:58 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:09:59 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:09:59 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:09:59 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:09:59 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:10:00 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:00 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:10:00 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:00 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:10:00 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:00 Disconnected from Open E Cry. | 2014-12-03 12:10:00 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:00 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:10:03 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:10:03 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:10:03 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:10:03 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:10:04 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:04 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:10:04 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:04 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:10:04 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:04 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:10:04 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:04 Disconnected from Open E Cry. | 2014-12-03 12:10:04 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:04 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:10:07 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:10:07 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:10:07 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:10:07 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:10:08 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:08 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:10:08 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:08 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:10:08 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:08 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:10:08 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:08 Disconnected from Open E Cry. | 2014-12-03 12:10:08 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:08 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:10:11 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:10:11 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:10:12 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:10:12 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:10:12 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:12 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:10:13 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:13 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:10:13 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:13 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:10:13 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:13 Disconnected from Open E Cry. | 2014-12-03 12:10:13 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:13 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:10:16 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:10:16 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:10:17 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:10:17 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:10:18 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:18 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:10:18 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:18 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:10:18 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:18 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:10:18 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:18 Disconnected from Open E Cry. | 2014-12-03 12:10:18 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:18 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:10:21 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:10:21 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:10:21 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:10:21 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:10:22 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:22 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:10:22 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:22 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:10:22 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:22 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:10:22 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:22 Disconnected from Open E Cry. | 2014-12-03 12:10:22 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:22 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:10:25 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:10:25 OEC FIX Trading socket (952) | Connected. | 2014-12-03 12:10:26 OEC FIX Trading socket (952) | Starting SSL connection. | 2014-12-03 12:10:26 OEC FIX Trading socket (952) | SSL connection established. | 2014-12-03 12:10:28 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:28 OEC FIX Trading socket (952) | Closed. No error. | 2014-12-03 12:10:28 OEC FIX Trading socket (952) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:28 OEC FIX Trading socket (952) | SSL has been shut down. | 2014-12-03 12:10:28 OEC FIX Trading socket (952) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:28 OEC FIX Trading socket (952) | Shutdown and closed. | 2014-12-03 12:10:28 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:28 Disconnected from Open E Cry. | 2014-12-03 12:10:28 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:28 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:10:31 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:10:31 OEC FIX Trading socket (764) | Connected. | 2014-12-03 12:10:32 OEC FIX Trading socket (764) | Starting SSL connection. | 2014-12-03 12:10:32 OEC FIX Trading socket (764) | SSL connection established. | 2014-12-03 12:10:33 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:33 OEC FIX Trading socket (764) | Closed. No error. | 2014-12-03 12:10:34 OEC FIX Trading socket (764) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:34 OEC FIX Trading socket (764) | SSL has been shut down. | 2014-12-03 12:10:34 OEC FIX Trading socket (764) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:34 OEC FIX Trading socket (764) | Shutdown and closed. | 2014-12-03 12:10:34 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:34 Disconnected from Open E Cry. | 2014-12-03 12:10:34 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:34 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:10:37 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:10:37 OEC FIX Trading socket (928) | Connected. | 2014-12-03 12:10:37 OEC FIX Trading socket (928) | Starting SSL connection. | 2014-12-03 12:10:37 OEC FIX Trading socket (928) | SSL connection established. | 2014-12-03 12:10:37 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:38 OEC FIX Trading socket (928) | Closed. No error. | 2014-12-03 12:10:38 OEC FIX Trading socket (928) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:38 OEC FIX Trading socket (928) | SSL has been shut down. | 2014-12-03 12:10:38 OEC FIX Trading socket (928) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:38 OEC FIX Trading socket (928) | Shutdown and closed. | 2014-12-03 12:10:38 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:38 Disconnected from Open E Cry. | 2014-12-03 12:10:38 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:38 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:10:41 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:10:41 OEC FIX Trading socket (928) | Connected. | 2014-12-03 12:10:42 OEC FIX Trading socket (928) | Starting SSL connection. | 2014-12-03 12:10:42 OEC FIX Trading socket (928) | SSL connection established. | 2014-12-03 12:10:43 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:43 OEC FIX Trading socket (928) | Closed. No error. | 2014-12-03 12:10:43 OEC FIX Trading socket (928) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:43 OEC FIX Trading socket (928) | SSL has been shut down. | 2014-12-03 12:10:43 OEC FIX Trading socket (928) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:43 OEC FIX Trading socket (928) | Shutdown and closed. | 2014-12-03 12:10:43 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:43 Disconnected from Open E Cry. | 2014-12-03 12:10:43 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:43 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:10:46 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:10:46 OEC FIX Trading socket (928) | Connected. | 2014-12-03 12:10:47 OEC FIX Trading socket (928) | Starting SSL connection. | 2014-12-03 12:10:47 OEC FIX Trading socket (928) | SSL connection established. | 2014-12-03 12:10:47 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:47 OEC FIX Trading socket (928) | Closed. No error. | 2014-12-03 12:10:48 OEC FIX Trading socket (928) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:48 OEC FIX Trading socket (928) | SSL has been shut down. | 2014-12-03 12:10:48 OEC FIX Trading socket (928) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:48 OEC FIX Trading socket (928) | Shutdown and closed. | 2014-12-03 12:10:48 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:48 Disconnected from Open E Cry. | 2014-12-03 12:10:48 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:48 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:10:51 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:10:51 OEC FIX Trading socket (1112) | Connected. | 2014-12-03 12:10:51 OEC FIX Trading socket (1112) | Starting SSL connection. | 2014-12-03 12:10:51 OEC FIX Trading socket (1112) | SSL connection established. | 2014-12-03 12:10:53 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:53 OEC FIX Trading socket (1112) | Closed. No error. | 2014-12-03 12:10:53 OEC FIX Trading socket (1112) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:53 OEC FIX Trading socket (1112) | SSL has been shut down. | 2014-12-03 12:10:53 OEC FIX Trading socket (1112) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:53 OEC FIX Trading socket (1112) | Shutdown and closed. | 2014-12-03 12:10:53 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:53 Disconnected from Open E Cry. | 2014-12-03 12:10:53 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:53 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:10:56 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:10:56 OEC FIX Trading socket (1780) | Connected. | 2014-12-03 12:10:57 OEC FIX Trading socket (1780) | Starting SSL connection. | 2014-12-03 12:10:57 OEC FIX Trading socket (1780) | SSL connection established. | 2014-12-03 12:10:58 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:58 OEC FIX Trading socket (1780) | Closed. No error. | 2014-12-03 12:10:59 OEC FIX Trading socket (1780) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:10:59 OEC FIX Trading socket (1780) | SSL has been shut down. | 2014-12-03 12:10:59 OEC FIX Trading socket (1780) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:10:59 OEC FIX Trading socket (1780) | Shutdown and closed. | 2014-12-03 12:10:59 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:10:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:10:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:10:59 Disconnected from Open E Cry. | 2014-12-03 12:10:59 Will reconnect to the server in 3.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:10:59 Open E Cry FIX | Connecting to server prod.openecry.com:9400. | 2014-12-03 12:11:02 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-12-03 12:11:02 OEC FIX Trading socket (1780) | Connected. | 2014-12-03 12:11:03 OEC FIX Trading socket (1780) | Starting SSL connection. | 2014-12-03 12:11:03 OEC FIX Trading socket (1780) | SSL connection established. | 2014-12-03 12:11:04 OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:11:04 OEC FIX Trading socket (1780) | Closed. No error. | 2014-12-03 12:11:04 OEC FIX Trading socket (1780) | SSL shutdown indicates not able to send 'close notify'. | 2014-12-03 12:11:04 OEC FIX Trading socket (1780) | SSL has been shut down. | 2014-12-03 12:11:04 OEC FIX Trading socket (1780) | SSL object has been freed. SSL state is now disconnected. | 2014-12-03 12:11:04 OEC FIX Trading socket (1780) | Shutdown and closed. | 2014-12-03 12:11:04 OEC FIX Trading: Socket connection was closed without any logout messages sent or received. | 2014-12-03 12:11:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-03 12:11:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-03 12:11:04 Disconnected from Open E Cry. | 2014-12-03 12:11:04 Will reconnect to the server in 3.0 minutes Select 'File >> Disconnect' to prevent further connection attempts. | 2014-12-03 12:11:04 |
| [2014-12-03 18:15:56] |
The problem is the OEC server is closing the connection after the Logon message is sent: OEC FIX Trading: Sending the Logon message. | 2014-12-03 12:10:53 OEC FIX Trading socket (1112) | Closed. No error. | 2014-12-03 12:10:53 For help with this, refer to this section here: http://www.sierrachart.com/index.php?page=doc/openecry.php#OECConnectionProblem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
