Date/Time: Wed, 05 Feb 2025 09:43:53 +0000
X /Y AXIS CONSTANT RELATIONSHIP
View Count: 1073
[2014-12-03 16:29:39] |
User57072 - Posts: 49 |
http://www.sierrachart.com/image.php?l=1417623848390.png The Grid Lines in the attachment are almost squared. Is there anyway to set the x/y axis so the ratio will remain constant when enlarging or decreasing the chart size ? |
[2014-12-03 17:59:08] |
Only if the vertical and horizontal pixel ratio remains the same. This is something we have no control over.
[2014-12-03 18:19:17] |
Can you give a brief description of this. And what if anything can i do ?
[2014-12-04 03:34:12] |
The only practical advice we can offer is when you are changing the size of the window you need to change it in such a way to maintain the same ratio of vertical to horizontal height so that the grid remains square. But we assume that you already know this.
